Magnus Olsson
COMSOL Employee
5 years ago
20 août 2019, 11:14 UTC−4
Updated:
5 years ago
20 août 2019, 11:11 UTC−4
Dear Nina,
What kind of moving mesh are you referring to? It should work for rigid body motion, setting the "Material type" in Ampère's Law to "Solid". It has not been implemented for freely deforming domains as it is not clear how the magnetization should transform in that case. In general, freely deforming solids with any kind of "polarization" are problematic as there is no "a priori correct way" for such a material to behave. You can compare to magnetostriction which is an established such material model - but not all materials are magnetostrictive.
Magnus
Dear Nina,
5 years ago
20 août 2019, 16:55 UTC−4
Dear Magnus
I mean the rotation of the rotor with respect to the stator of the electrical machines. as the rotor rotates, the geometry of the machine varies. so, mesh movement must be employed.
I was wondering if the rotor and stator areas are meshed, and the air-gap between them is considered as boundary element (in which only the boundary is meshed), then the J-A hysteresis model works?
Best regards
Nina
Dear Magnus
Best regards
Nina
