Element type
I was wondering if it was possible to select a different element type in a certain domain.
The element in my geometry are quadratic, but I would like to set to cubic elements to a certain domain.
How can I do that ?
Alain
1 Reply Last Post 17 nov. 2011, 11:08 UTC−5
Posted: 1 decade ago 17 nov. 2011, 11:08 UTC−5
you speak of the space function I presume, then try to add a new main physics node where you can redefine the discretisation for only apart of the full model
If its the mesh, you can mesh manually, but linking Quads to tet's require a "converted" surface
Hi you speak of the space function I presume, then try to add a new main physics node where you can redefine the discretisation for only apart of the full model If its the mesh, you can mesh manually, but linking Quads to tet's require a "converted" surface -- Good luck Ivar
