Jeff Hiller
COMSOL Employee
6 years ago
12 juil. 2019, 08:52 UTC−4
Updated:
6 years ago
12 juil. 2019, 08:45 UTC−4
Hello Pablo,
What you are talking about here is referred to as a fluid-structure interaction (or FSI, for short) problem. FSI is something COMSOL is very well suited for. There are several different possible configurations, starting with whether the two physics are one-way coupled or two-way coupled. In your case, if the deformation of the membrane is small, you may be able to neglect the impact its deformation has on the fluid flow, making it one-way coupled (In your case, on a fixed geometry). If on the other hand the deflection of the membrane is large, or if the point of your analysis is to determine how much the flow is affected by the membrane deflection, then you will need to treat it as two-way coupled. Next is the question of how to treat that membrane: can you/do you want to model it as a shell/plate (possible if it has a high aspect ratio) or is it thick enough that you model it as a solid (i.e. accounting for its thickness in the Geometry section of your model).
In the situation where you neglect the impact of the membrane deformation on the flow and you model the membrane as a solid, you should be able perform this simulation without the Structural Mechanics Module or the MEMS Module (assuming that there is no other complication involved that you have not mentioned, such as could come from a material behavior, large strains, etc). It would be conceptually similar to this model of fluid flow over a solar panel (But your situtation is simpler because you likely have a much lower Reynolds number so you presumably don't need to account for turbulence): https://www.comsol.com/blogs/efficient-solar-panel-design-improves-pv-industry/ . If you go for the two-way coupling, or if you want to use a plate or shell representation for the membrane, then you will need the Structural Mechanics Module
Here are a couple of webinars that you may find helpful to get going:
https://www.comsol.com/video/intro-to-modeling-fluid-structure-interaction-in-comsol
https://www.comsol.com/video/modeling-fluid-structure-interaction-with-comsol-multiphysics
Jeff Hiller
Hello Pablo,
Pablo Garcia De Madinabeitia
6 years ago
24 juil. 2019, 06:21 UTC−4
Updated:
6 years ago
24 juil. 2019, 06:20 UTC−4
Dear Jeff,
Thanks a lot for your response. I found the links very helpful and clarifying.
However, I still wonder if we would need to purchase structural mechanics module in order to compute a 2D/3D simulation of this FSI simulations (or simply, could we just get through with the basic functionalities of structural mechanics?). I need to simulate how much force (mechanical load) I need to close a pipe at a fixed flowrate, and the other way around: how much flowrate I have to set to overcome pipe closing mechanical load. I believe my problem would be then a two-way coupled problem. I would be thankful if you could confirm my suspicions.
Thank you very much!
Pablo
Dear Jeff,
Pablo
Jeff Hiller
COMSOL Employee
6 years ago
24 juil. 2019, 08:26 UTC−4
Updated:
6 years ago
24 juil. 2019, 08:48 UTC−4
Hi Pablo,
Indeed, it does not sound like the simple case where the flow can be evaluated on the undeformed geometry as in the solar panel example mentioned in my earlier post. In fact, since you mention that the membrane may deflect so much as to close the pipe, it makes me think that the membrane may experience large strains, which would be another reason for needing the Structural Mechanics Module.
PS: BTW, the pipe completely closing would lead to a change in topology for the fluid domain. This blog presents a way to handle that difficulty.
Jeff Hiller
Hi Pablo,
PS: BTW, the pipe completely closing would lead to a change in topology for the fluid domain. [This blog](https://www.comsol.com/blogs/tips-using-wall-distance-interface/) presents a way to handle that difficulty.
5 years ago
1 sept. 2019, 13:53 UTC−4
Dear Jeff,
Back again with this FSI issue, I understand now that is a 2-way coupled problem.
Indeed I have had the chance to face the problem. When I define deforming domain (a membrane moves) then, I cannot define a force in the structural mechanics physics.
Could you provide any guidance on how to proceed?
Pablo
Dear Jeff,
Pablo
