Thermal Simulation Package Simple Model
Zainal Firdaus Bin Zainal Amini
Hello there all,
I am currently doing a simple thermal simulation to see the heat profile of an IC package.
Creating a detailed package model would be time consuming so I created a block model to mimic the package instead.
My question is: Its only a simple block model so which materials thermal conductivity should I set it to be? I tried setting it to "MOLD" which has a low thermal conductivity of 0.8 and the results seems to differ by quite a lot in comparison to what it should be.
Is there any particular thermal conductivity value that I i should set it to?
Thank you in advance!
1 Reply Last Post 5 juil. 2019, 18:26 UTC−4
Posted: 5 years ago 5 juil. 2019, 18:26 UTC−4
Updated: 5 years ago 5 juil. 2019, 18:19 UTC−4
You haven't said what KIND of package you are trying to model. If, for example, you were modeling the old-fashioned dual in-line package, you would need to model the lead frame in addition to the plastic. The metal of the lead frame has considerably higher thermal conductivity than the plastic molded around the lead frame and chip.
As far as the thermal conductivity of the plastic is concerned- you would need to either get that from the manufacturer or measure it yourself.
Getting appropriate material parameters and deciding what details need to be modeled are part of the simulation process and may require some domain knowledge.
D.W. Greve
You haven't said what KIND of package you are trying to model. If, for example, you were modeling the old-fashioned dual in-line package, you would need to model the lead frame in addition to the plastic. The metal of the lead frame has considerably higher thermal conductivity than the plastic molded around the lead frame and chip. As far as the thermal conductivity of the plastic is concerned- you would need to either get that from the manufacturer or measure it yourself. Getting appropriate material parameters and deciding what details need to be modeled are part of the simulation process and may require some domain knowledge. D.W. Greve
