Can you shift a 2-d cut plane?
Posted 3 nov. 2011, 10:00 UTC−4 Results & Visualization Version 4.2 1 Reply
I've built a 3-d model using MIMICS, but some of my geometry doesn't line up perfectly along COMSOL's coordinate system.
I want to evaluate my 3-d model in 2-d cut plane sections, but I need to rotate my entire model (or just the results) along a single axis. Is there a way to do this in results?
For example, I want to rotate the model 23 degrees in the +Z direction, then I want to look at the corresponding xy plane at certain plane levels.
Ben
Ben
1 Reply Last Post 4 nov. 2011, 03:10 UTC−4
