Edgar J. Kaiser
Certified Consultant
5 years ago
15 avr. 2019, 10:48 UTC−4
Luciana,
as far as I can see you applied a ground BC on all surfaces of this little vehicle (the robot?). So the material it is made of doesn't matter.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Luciana,
Cheers
Edgar
5 years ago
15 avr. 2019, 11:14 UTC−4
Thank you very much for your reply. I have corrected the Electric Fields simulations.
For the magnetic fields we are using the Magnectic Fields Physics. What would be the correct BC to use on the robot to show the magnectic field on the its surface and represent the differences in the field according to the materials used?
Edgar J. Kaiser
5 years ago
15 avr. 2019, 11:28 UTC−4
I don't think you need a specific BC. Just assign the material and leave the default continuity. If you have time dependent magnetic fields you may consider impedance BC on metallic faces if you don't need to resolve the skin effect. If you have only static fields and no currents you can use mfnc instead of mf.
Edgar J. Kaiser
www.emphys.com
