LiveLink with Excel - extract data from an exiting Table
I am trying to extract data from the results and show it in excel. I followed the following procedure:
  1. In COMSOL I was able to define a table and save its content on an excel file
  2. Saved the mph as VBA
  3. open excel and pates the VBA code into a new module
  4. run the script
Up to now everything was OK.
So I have a table (tbl1) with two columns (frequency and gain) Now I need to perform what in Matlab code would be
Gain = mphtable(model,'tbl1'); Freq=Gain.data(:,1); Gain_dB=Gain.data(:,2);
I could not find the VBA equivalent of these 3 MATLAB lines (and yes, I did looked into the LiveLink for Excel, but in the EXTRACTING DATA section I was not able to find what I was looking for, or misinterpreted)
Any ideas?
Tuli
1 Reply Last Post 10 avr. 2019, 07:05 UTC−4
Kristoffer Raneflod COMSOL Employee
Posted: 5 years ago 10 avr. 2019, 07:05 UTC−4
Perhaps the following code can be used in your case:
Dim tableData() As String
tableData = model.result.get_table("tbl1").getTableData(True)
Dim Freq, Gain As Variant
Freq = Application.WorksheetFunction.Transpose(Application.WorksheetFunction.Index(tableData, 0, 1)) 'Retrieve the values from the first column, and transpose.
Gain = Application.WorksheetFunction.Transpose(Application.WorksheetFunction.Index(tableData, 0, 2)) 'Retrieve the values from the second column, and transpose.
The code use the Index worksheet function for retrieving the values from the columns, and the Transpose worksheet function for transposing the data.
Best regards, Kristoffer
Hello, Perhaps the following code can be used in your case: Dim tableData() As String tableData = model.result.get_table("tbl1").getTableData(True) Dim Freq, Gain As Variant Freq = Application.WorksheetFunction.Transpose(Application.WorksheetFunction.Index(tableData, 0, 1)) 'Retrieve the values from the first column, and transpose. Gain = Application.WorksheetFunction.Transpose(Application.WorksheetFunction.Index(tableData, 0, 2)) 'Retrieve the values from the second column, and transpose. The code use the Index worksheet function for retrieving the values from the columns, and the Transpose worksheet function for transposing the data. Best regards, Kristoffer
