COMSOL V4.2 right click issues when making 1D models
hi guys, i'm hitting a weird problem when trying to make some simple 1D models. i get random problems activating the right click menu on model nodes. sometimes the menu will appear, other times it will not display so i can't add new components of rename of disable existing ones.
i'm using a mac with osx lion, i already downloaded the patch
any help appreciated.
3 Replies Last Post 11 avr. 2012, 14:41 UTC−4
Hello Stephen Mackintosh
Posted: 1 decade ago 12 déc. 2011, 05:56 UTC−5
I am also getting the same problem on Mac OSX Lion with a 2D axi-symmetric model in version 4.2a. When I right-click on mesh or solid mechanics, nothing happens.
Did you (or anyone) find a solution to the problem?
Cheers!
Hi, I am also getting the same problem on Mac OSX Lion with a 2D axi-symmetric model in version 4.2a. When I right-click on mesh or solid mechanics, nothing happens. Did you (or anyone) find a solution to the problem? Cheers!
Posted: 1 decade ago 22 déc. 2011, 19:06 UTC−5
Did you find any solution? same problem here...
Posted: 1 decade ago 11 avr. 2012, 14:41 UTC−4
Got the same problem with my 3D model. After a failed run, the structural mechanics node does not display the right-click context menu anymore. All other nodes do. Restart doesn't help, I can basically start over... Any help?
