"Unable to write solution data" error in parameter sweep
I am new to COMSOL. Now I'm trying to calculate a deflection of a piezoelectric bimorph with a complex geometry when dc voltage is applied, . I have created working model which calculated good results, very close to my experiments, but when I tried to make a sweep with one of parameters the error of solver "Unable to write solution data." occured
Any help will be highly appreciated.
Ilya
2 Replies Last Post 9 janv. 2019, 10:33 UTC−5
Posted: 6 years ago 7 janv. 2019, 15:20 UTC−5
Ilya,
Try to close Comsol, then open model and solve again.
Sergei
Ilya, Try to close Comsol, then open model and solve again. Regards, Sergei
Posted: 6 years ago 9 janv. 2019, 10:33 UTC−5
Sergei, it seems to be working, the program calculated the entire sweep range without the error.
Thank you!
Sergei, it seems to be working, the program calculated the entire sweep range without the error. Thank you!
