Radiation - Discrete Ordinates
In the simple model attached an incident irradiation of 10 W/m² is set at the internal walls, but when solving a value as high as ~50 W/m² is reached at this surface. Why?
2 Replies Last Post 25 déc. 2018, 14:42 UTC−5
Posted: 6 years ago 25 déc. 2018, 14:17 UTC−5
Updated: 6 years ago 25 déc. 2018, 14:18 UTC−5
Hi Natan,
I see in your model that incident radiation is defined in terms of W/(m^2 * sr). So there may be a factor of approx. 2*pi in between, since the surface approx. looks at a half space?
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi Natan, I see in your model that incident radiation is defined in terms of W/(m^2 * sr). So there may be a factor of approx. 2*pi in between, since the surface approx. looks at a half space? Cheers Edgar
Posted: 6 years ago 25 déc. 2018, 14:42 UTC−5
Hi Edgar,
Thank you. That makes sense.
Natan
Hi Edgar, Thank you. That makes sense. Regards, Natan
