How to apply initial stress
Hi!
I made a model of a string with initial stress using a truss element and I obtained exactly the same eigenfrequencys than manually using theorical formulas.
Now I want to make the model using a beam element, but I get totally different results. Moreover, changing the value of the initial stress, the eigenfrequency doesn`t vary, wich is no correct.
So, wich is the problem?
Bruno.
2 Replies Last Post 6 juil. 2012, 13:18 UTC−4
Hello Bruno Rango
Posted: 1 decade ago 6 juil. 2012, 04:53 UTC−4
I have absolutely similar problem.
Is there any standard solution to define the pre-stress in the uni-/bimorph structures?
Somehow it is routine task, to look for the eigenfrequencies modified by the technology-induced
strain/stress variations.
I will be very thankfull for the advice from someone solved the problem.
At the moment I am using analytical formulas for simple bridges, but for mor complex geometries
it does not work of course.
I have absolutely similar problem. Is there any standard solution to define the pre-stress in the uni-/bimorph structures? Somehow it is routine task, to look for the eigenfrequencies modified by the technology-induced strain/stress variations. I will be very thankfull for the advice from someone solved the problem. At the moment I am using analytical formulas for simple bridges, but for mor complex geometries it does not work of course.
Posted: 1 decade ago 6 juil. 2012, 13:18 UTC−4
"my way" is to apply a stationary solver case first and use that as intial conditions (with or without remeshing, all depends)
Hi "my way" is to apply a stationary solver case first and use that as intial conditions (with or without remeshing, all depends) -- Good luck Ivar
