Cyclic Boundary Condition
I have porous pipe flow with temp and velocity at inlet and pressure and heat outflow at exit.
I am doing a time dependent analysis and after say 30 min, I would like to reverse the boundary conditions.
This process needs to be done continuously until a quasi static state is reached. However I am only able to achieve this manually by changing the BC after every run.
Is is possible to automate this process? Any help is greatly appreciated.
Thanks.
Shriram R
2 Replies Last Post 24 août 2011, 15:10 UTC−4
Posted: 1 decade ago 22 août 2011, 01:50 UTC−4
have you tried to combine a parametric sweep with a transient, and use your "Parameter" to switch the BC's, you might need to fiddle the equations of the BC's or make you own "switchable" but I believe that should work nicely
Hi have you tried to combine a parametric sweep with a transient, and use your "Parameter" to switch the BC's, you might need to fiddle the equations of the BC's or make you own "switchable" but I believe that should work nicely -- Good luck Ivar
Posted: 1 decade ago 24 août 2011, 15:10 UTC−4
Hi Ivar,
Thank you very much for your input.
However I couldn't get it to work using parametric study, but I have been able to modify the matlab code and set up a loop to continuously change the boundary condition back and forth.
Now I just have 1 question. As you can see I am doing a time dependent analysis upto 1800 s.
But I want to use the last time step of solver 1 (sol1) as initial condition for solver 2 (sol2). However I can't see how the last time step of solver 1 at 1800 s can be specified, as from the code I am unable to see this.
Thank you.
Shriram
model.sol('sol1').runAll;
model.sol('sol2').feature('st1').name('Compile Equations: Time Dependent 1');
model.sol('sol2').feature('st1').set('studystep', 'time1');
model.sol('sol2').feature('v1').set('control', 'time1');
model.sol('sol2').feature('v1').set('initmethod', 'sol');
model.sol('sol2').feature('v1').set('initsol', 'sol1');
model.sol('sol2').feature('t1').set('control', 'time1');
model.sol('sol2').feature('t1').set('tlist', '0 1 2 5 10 18 25 50 100 300 600 900 1200 1500 1800');
model.sol('sol2').feature('t1').set('maxorder', '2');
model.sol('sol2').feature('t1').feature('fc1').set('maxiter', '5');
model.sol('sol2').feature('t1').feature('fc1').set('jtech', 'once');
model.sol('sol2').runAll;
Hi Ivar, Thank you very much for your input. However I couldn't get it to work using parametric study, but I have been able to modify the matlab code and set up a loop to continuously change the boundary condition back and forth. Now I just have 1 question. As you can see I am doing a time dependent analysis upto 1800 s. But I want to use the last time step of solver 1 (sol1) as initial condition for solver 2 (sol2). However I can't see how the last time step of solver 1 at 1800 s can be specified, as from the code I am unable to see this. Thank you. Shriram . . . . . model.sol('sol1').runAll; model.sol('sol2').feature('st1').name('Compile Equations: Time Dependent 1'); model.sol('sol2').feature('st1').set('studystep', 'time1'); model.sol('sol2').feature('v1').set('control', 'time1'); model.sol('sol2').feature('v1').set('initmethod', 'sol'); model.sol('sol2').feature('v1').set('initsol', 'sol1'); model.sol('sol2').feature('t1').set('control', 'time1'); model.sol('sol2').feature('t1').set('tlist', '0 1 2 5 10 18 25 50 100 300 600 900 1200 1500 1800'); model.sol('sol2').feature('t1').set('maxorder', '2'); model.sol('sol2').feature('t1').feature('fc1').set('maxiter', '5'); model.sol('sol2').feature('t1').feature('fc1').set('jtech', 'once'); model.sol('sol2').runAll;
