Visualization Transparency
Does anyone know how to control transparency of a particular plot?
For instance, I would like to show what is happening in the contact area of two bodies in contact, while simultaneously showing the two bodies.
Ideally, I could mirror the solution of the second body since it was solved as a symmetric problem. In this way, I could visualize both bodies and the contact area would not be hidden.
However, I would be content with just controlling transparency of the plot.
3 Replies Last Post 12 mars 2014, 18:18 UTC−4
Zoran Vidakovic, COMSOL COMSOL Employee
Posted: 1 decade ago 7 juil. 2011, 12:31 UTC−4
Dear Marcus
Have a look here: www.ch.comsol.com/community/forums/general/thread/16157/
In addition, you can control the magnitude of the transparency under Model 1 > Definitions > View 1 (in 3D: see attached image).
I hope this helps!
Zoran
Dear Marcus Have a look here: http://www.ch.comsol.com/community/forums/general/thread/16157/ In addition, you can control the magnitude of the transparency under Model 1 > Definitions > View 1 (in 3D: see attached image). I hope this helps! Best regards, Zoran
Posted: 1 decade ago 8 juil. 2011, 10:02 UTC−4
This is helpful for occluded geometry, but it does not affect the transparency of plotted solutions.
Perhaps I should have been more specific.
This is helpful for occluded geometry, but it does not affect the transparency of plotted solutions. Perhaps I should have been more specific.
Posted: 1 decade ago 12 mars 2014, 18:18 UTC−4
Does anyone know the solution to this? I am having the same issue - I can have transparencies when viewing the model geometry, but not when plotting results.
