magnetics (mf) question
in a magnetics (mf) problem If I have a conducting domain with a varying cross section
and I wish to inject a given current as an initial condition.
How do I define the external current density so that I have the same current in any cross section?
thanks
David
1 Reply Last Post 28 juin 2011, 07:02 UTC−4
Posted: 1 decade ago 28 juin 2011, 07:02 UTC−4
hi,
on ec there is node called external current density, there is also boundary current source.
just give 1[A]/boundaryarea[mm^2]. in every cross section the current should be the same, but current density not.
regards
akmal
hi, on ec there is node called external current density, there is also boundary current source. just give 1[A]/boundaryarea[mm^2]. in every cross section the current should be the same, but current density not. regards akmal
