Jeff Hiller
COMSOL Employee
6 years ago
25 juil. 2018, 08:28 UTC−4
Updated:
6 years ago
31 janv. 2019, 09:52 UTC−5
Hello Feng,
You must be referring to this tutorial: https://www.comsol.com/model/simulation-of-an-ion-sensitive-field-effect-transistor-isfet-45341
If so, please note that that tutorial requires
- COMSOL Multiphysics®, and
- Semiconductor Module, and
- Batteries & Fuel Cells Module, Chemical Reaction Engineering Module, Corrosion Module, Electrochemistry Module, Electrodeposition Module, or Microfluidics Module
From what you describe, it sounds like your license does not currently include any of the products in 3/ above. You can check on that by going to File > Licensed and Used Products.
Jeff Hiller
Hello Feng,
1. COMSOL Multiphysics®, and
2. Semiconductor Module, and
3. Batteries & Fuel Cells Module, Chemical Reaction Engineering Module, Corrosion Module, Electrochemistry Module, Electrodeposition Module, or Microfluidics Module
6 years ago
25 juil. 2018, 11:28 UTC−4
Dear Jeff,
Thank you for your reply. I am still having trouble finding which are required. I want to have four species in transport of diluted species and also the transport mechanism of migration in electric field. What do I need? Do I need all those you mentioned in 3?
Thank you so much!
Feng
Dear Jeff,
Thank you so much!
Feng
Jeff Hiller
COMSOL Employee
6 years ago
25 juil. 2018, 11:34 UTC−4
From the 3rd bullet, you need any one of those modules. I should have typed
Batteries & Fuel Cells Module, or Chemical Reaction Engineering Module, or Corrosion Module, or Electrochemistry Module, or Electrodeposition Module, or Microfluidics Module
Jeff Hiller
6 years ago
25 juil. 2018, 11:35 UTC−4
Dear Jeff,
Thank you so much! That really helps!
Feng
Dear Jeff,
Feng
