Parametric Sweep to vary boundary condition type in transient analysis
I am running a thermal transient model within which I would like to change the type of some boundaries between thermal insulation and predefined temperature several times. Doing this manually is quite time consuming and cannot be 100% assured to be error free.
I came across several discussions here in the forum that mentioned that Parametric Sweep can be used to automate this process. None of these discussions have described how can this be done. I am wondering if anyone here have done it and is welling to teach me that. May be a model including this step will help me figure this out.
Sherif
p.s. I recently switched to COMSOL 4.1 after using COMSOL 3.5a for the last 3 years so I am not an expert yet with all the tools in COMSOL 4.1
2 Replies Last Post 13 juin 2011, 11:48 UTC−4
Posted: 1 decade ago 6 juin 2011, 10:42 UTC−4
I believe (but as usual I might be wrong ;) that you will have to write out the equations yourself, as in v4 normally you cannot have two conflicting BC on the same boundary without seeing one override the other.
So this means for me looking at the equations for the two BC and combining them, probably with a weak contraint manually, with a time dependent bolean parameter (perhaps with smmothened transition to avoid spikes and convergence issues)
Hi I believe (but as usual I might be wrong ;) that you will have to write out the equations yourself, as in v4 normally you cannot have two conflicting BC on the same boundary without seeing one override the other. So this means for me looking at the equations for the two BC and combining them, probably with a weak contraint manually, with a time dependent bolean parameter (perhaps with smmothened transition to avoid spikes and convergence issues) -- Good luck Ivar
Posted: 1 decade ago 13 juin 2011, 11:48 UTC−4
Hi Ivar,
Thanks for your response to my question.
I just wanted to let you know that I have found a very simple way to vary the type of the boundary condition with time or with any other variable. This way does not depend on using the weak constraint that you proposed which I believe would work but will need a massive amount of work to do it.
My approach is to use COMSOL with MATLAB, using a for loop and conditional statements. It worked perfectly and all my runs now are automated ;)
I just wanted to post this answer for any one else who may have the same question.
Sherif
Hi Ivar, Thanks for your response to my question. I just wanted to let you know that I have found a very simple way to vary the type of the boundary condition with time or with any other variable. This way does not depend on using the weak constraint that you proposed which I believe would work but will need a massive amount of work to do it. My approach is to use COMSOL with MATLAB, using a for loop and conditional statements. It worked perfectly and all my runs now are automated ;) I just wanted to post this answer for any one else who may have the same question. Thanks Sherif
