Compressibility in Fluid-Structure Interaction
Posted 17 juil. 2018, 17:07 UTC−4 MEMS & Piezoelectric Devices Version 5.3 0 Replies
Hi Everyone,
I am performing a simulation using the FSI interface in Comsol 5.3. In the settings of the FSI under the physical model where we select the compressibility option, there two options are listed: - Compressible (Ma<0.3). - Incompressible.
As far as I understand it should be the other way around (at least for air); incompressible for Mach numbers below 0.3, and compressible for Mach numbers above 0.3.
I did a density plot, but since I was using water as fluid with relatively small velocity it wouldn't be of much help.
Am I misunderstanding here or is this a mistake?
Many Thanks,
Hello Mohamed Abdelhamid
