How to see the temperature values in Celsius along with the temperature field on COMSOL?
Is there a way to view the temperature values in Celsius along with the temperature field in the Tecplot or in another post-view tool?
I appreciate the help. My email is rogerio6497@gmail.com
1 Reply Last Post 17 juil. 2018, 16:54 UTC−4
Posted: 6 years ago 17 juil. 2018, 16:54 UTC−4
Hi Rogerio,
By default temperature values in COMSOL are in Kelvin. You can see the values in ºC if you go to the expression you are plotting and instead of "T" you use "T-273.15". You can also use "[degC]" to use the units in celsius and COMSOL will convert it to Kelvin for calculations.
Regards, Nichal
Hi Rogerio, By default temperature values in COMSOL are in Kelvin. You can see the values in ºC if you go to the expression you are plotting and instead of "T" you use "T-273.15". You can also use "[degC]" to use the units in celsius and COMSOL will convert it to Kelvin for calculations. Regards, Nichal
