20 nov. 2009, 04:45 UTC−5
Is there any work around way to anlayze the speaker membrane large deformation. The thickness of the membrane is very small comparing to its size. Please help. Many thanks.
20 nov. 2009, 07:19 UTC−5
You are asking an interesting question there about large deformations theory and the simplified shell models. These type of questions are typicaly what I ask support.
Normally with bulk structural mode the large deformations uses Greens stress, versus Engierring stress for small deformations, but when using shells, isn't all this predefined ?
Il you check the smeref.pdf doc, you see that large deformations is mentionned for trusses, but not explicitely for beams nor for shells !
When you open the shell and beam modes in 2D or 3D [V3.5a] there is NO option for large deformations. therefore I would conclude that the default shell items are NOTcompatible with large deformations.
I would use bulk 3D, even if correct meshing is somewhat more complex.
9 years ago
30 déc. 2015, 03:45 UTC−5
I have the same question.
When I calculate the force vs deformation for a ultrathin membrane, such as graphene, which model is most suitable? 3D membrane? or 2D plate is fine too?
