27 avr. 2011, 06:35 UTC−4
May be because your system is not strongly single mode something which port boundaries are ideally suited for. All the modes apart from the specific mode the port can absorb get (partially) back-reflected resulting in erratic results.
27 avr. 2011, 07:00 UTC−4
Thank you for your answer,
I am actually simulating a broad range but in single mode range even with very dense meshes I still obtain the same behaviour.
[QUOTE]
[/QUOTE]
6 sept. 2011, 10:44 UTC−4
To me it also sounds like you system is not strictly single mode.
I guess otherwise you made your system work combining ports and pmls. I am curious to hear how you made it work. Perhaps you could upload you mph file. I am trying to combine ports and pmls in 3d but I am getting a strange error, which means I can still run the simulations but the result is no fields. I should say my simulations are ok without pmls.
6 sept. 2011, 14:48 UTC−4
Hi Claus,
In order to combine port boundaries and PML, I followed the documentation in the below link, there is also case for 3D:
www.comsol.com/showroom/documentation/model/6141/
Hi Claus,
http://www.comsol.com/showroom/documentation/model/6141/
12 juin 2013, 17:05 UTC−4
Hi Claus,
Hi Elif,
I can not open the link now. Is that possible you may send me the document? I have the problem that if I use PML and port together, there is no electric field.
Thank you very much.
[QUOTE]
Hi Claus,
[/QUOTE]
Hi Elif,
