6 years ago
17 avr. 2018, 03:41 UTC−4
It seems that, the light intensity (unit:W/m2) of the refracted light should be calculated by,
I2=n2/n1·tp^2·I1
rather than
I2=n2/n1·cos(θ2)/cos(θ1)·tp^2·I1.
The latter one, which is actually used in COMSOL to calculate the light intensity (parameter: gop.I), should be the ray power.
It can be seen in wikipedia about the Fresnel Equations, https://en.wikipedia.org/wiki/Fresnel_equations
I2=n2/n1·tp^2·I1
rather than
The latter one, which is actually used in COMSOL to calculate the light intensity (parameter: **gop.I**), should be the ray power.
Christopher Boucher
COMSOL Employee
6 years ago
18 avr. 2018, 14:54 UTC−4
The expression
matches the expression given in the literature for the transmittance or transmissivity. For example, in the notation of Born and Wolf, Principles of Optics (7th ed.), pp.43,
where is the transmittance and is the transmission coefficient.
Best Regards,
Chris
The expression
\mathcal{T} = \frac{J^{(t)}}{J^{(i)}} = \frac{n_2}{n_1}\frac{\cos\theta_t}{\cos\theta_i}\frac{\left|T\right|^2}{\left|A\right|^2}
where \mathcal{T} is the transmittance and T is the transmission coefficient.
Best Regards,
Chris
6 years ago
19 avr. 2018, 08:27 UTC−4
Hi, Boucher, I am very glad to receive your reply!
I have consult the Principles of Optics (7th ed.) by Born and Wolf.
I have noticed the formula that you refered,
T'=J(t)/J(i)=n2/n1·cos(θt)/cos(θi)·(T^2)/(A^2)
Actually, in the literature, J is regarded as the energy (or power) of the transmitted or the incident wave, whose unit is Joule or Watt. Thus the transmittance is the energy or power ratio between the two waves.
However,** the key of my question is that**, the parameter gop.I that calculated by the Ray Optics of COMSOL represents the light intensity and uses the unit of W/m2.
In fact, in your formula, the difference of the cross-sectional area between the refracted wave and the incident wave is included. So, in my opinion, it could not calculate the light intensity, but can be only used to calculate the ray energy or ray power.
Thanks!
Appendix
The expression
Best Regards,
Chris
I have consult the *Principles of Optics (7th ed.)* by Born and Wolf.
Actually, in the literature, **J** is regarded as the **energy (or power)** of the transmitted or the incident wave, whose unit is Joule or Watt. Thus the transmittance is the energy or power ratio between the two waves.
However,** the key of my question is that**, the parameter **gop.I** that calculated by the Ray Optics of COMSOL represents the light intensity and uses the unit of W/m2.
Thanks!
**Appendix**
>Hi,
>The expression
> Best Regards,
> Chris
