geomcomp and geomdel function in comsol 3.5a for matlab live link
Is there any equivalent function in comsol 5.1 as “geomcomp” and “geomdel” which is used to use in comsol 3.5a for matlab live link ? Or what is the meaning of the functions? I give an example code below :
g1=rect2(1.4E-8,0.2E-8,'base','corner','pos',[-0.2E-8,1.0E-8]);
g2=rect2(1.4E-8,0.2E-8,'base','corner','pos',[-0.2E-8,-0.2E-8]);
g3=rect2(0.2E-8,1.0E-8,'base','corner','pos',[-0.2E-8,0]);
g4=rect2(0.2E-8,1.0E-8,'base','corner','pos',[1.0E-8,0]);
g5=geomcomp({g1,g2,g3,g4},'ns',{'g1','g2','g3','g4'},'sf','g1+g2+g3+g4','edge','none');
g6=geomdel(g5);
2 Replies Last Post 12 avr. 2018, 06:24 UTC−4
Posted: 7 years ago 12 avr. 2018, 06:18 UTC−4
Updated: 7 years ago 12 avr. 2018, 10:39 UTC−4
geomcomp makes a composition of geometric objects. In this case it makes a union of the objects. geomdel removes interior boundaries.
In modern versions of Comsol your example looks like this (I have also attached the code as a file to make the code more readable).
import com.comsol.model.util.*
model = ModelUtil.create('Model');
model.modelNode.create('comp1', true);
model.geom.create('geom1', 2);
model.geom('geom1').model('comp1');
model.mesh.create('mesh1', 'geom1');
model.geom('geom1').create('r1', 'Rectangle');
model.geom('geom1').feature('r1').set('pos', {'-0.2e-8' '1e-8'});
model.geom('geom1').feature('r1').set('size', {'1.4e-8' '0.2e-8'});
model.geom('geom1').feature.duplicate('r2', 'r1');
model.geom('geom1').feature('r2').set('pos', {'-0.2e-8' '-0.2e-8'});
model.geom('geom1').feature.duplicate('r3', 'r2');
model.geom('geom1').feature('r3').set('size', {'0.2e-8' '1e-8'});
model.geom('geom1').feature('r3').set('pos', {'-0.2e-8' '0'});
model.geom('geom1').feature.duplicate('r4', 'r3');
model.geom('geom1').feature('r4').set('pos', {'1e-8' '0'});
model.geom('geom1').create('uni1', 'Union');
model.geom('geom1').feature('uni1').selection('input').set({'r1' 'r2' 'r3' 'r4'});
model.geom('geom1').feature('uni1').set('intbnd', false);
mphgeom(model)
Lars Gregersen
Comsol Denmark
Hi geomcomp makes a composition of geometric objects. In this case it makes a union of the objects. geomdel removes interior boundaries. In modern versions of Comsol your example looks like this (I have also attached the code as a file to make the code more readable). import com.comsol.model.util.* model = ModelUtil.create('Model'); model.modelNode.create('comp1', true); model.geom.create('geom1', 2); model.geom('geom1').model('comp1'); model.mesh.create('mesh1', 'geom1'); model.geom('geom1').create('r1', 'Rectangle'); model.geom('geom1').feature('r1').set('pos', {'-0.2e-8' '1e-8'}); model.geom('geom1').feature('r1').set('size', {'1.4e-8' '0.2e-8'}); model.geom('geom1').feature.duplicate('r2', 'r1'); model.geom('geom1').feature('r2').set('pos', {'-0.2e-8' '-0.2e-8'}); model.geom('geom1').feature.duplicate('r3', 'r2'); model.geom('geom1').feature('r3').set('size', {'0.2e-8' '1e-8'}); model.geom('geom1').feature('r3').set('pos', {'-0.2e-8' '0'}); model.geom('geom1').feature.duplicate('r4', 'r3'); model.geom('geom1').feature('r4').set('pos', {'1e-8' '0'}); model.geom('geom1').create('uni1', 'Union'); model.geom('geom1').feature('uni1').selection('input').set({'r1' 'r2' 'r3' 'r4'}); model.geom('geom1').feature('uni1').set('intbnd', false); mphgeom(model)
Posted: 7 years ago 12 avr. 2018, 06:24 UTC−4
Updated: 7 years ago 12 avr. 2018, 06:26 UTC−4
Lars Gregersen
Comsol Denmark
