undefined variable comp.2.ht.rhoref, coupling between heat transfer and laminar flow after upgrade to 5.3a
Hi everyone,
I m modelling a coupling between heat tranfer and laminar flaw using a nitf multiphysics coupling. My model runs welll in 5.3 but when i use 5.3a an erro msg comes out as if the solver can not find the reference density though it is set to be taken from ht interface.
error: undefined variable. -variable: comp1.ht.rhoref -Geometry: 11 Failed to evaluae the Jacobian of expression : dvol(((-comp1.ht.Ceff)comp1.ht.timeDerivative )Comp1.ht.
Can anyone give me a quick hint?
3 Replies Last Post 12 mars 2018, 04:36 UTC−4
Posted: 7 years ago 9 mars 2018, 16:26 UTC−5
Hi Habimana, I am facing a similar issue while trying to solve coupled phase change problem. Also, as you said your model did run in 5.3 right, if you don't mind could you kindly share the file with me
Posted: 7 years ago 10 mars 2018, 00:00 UTC−5
Updated: 7 years ago 10 mars 2018, 00:00 UTC−5
Hi Sai Phani Kiran Hota,
Have you found a way to solve the issue?
Hi Sai Phani Kiran Hota, Have you found a way to solve the issue?
Nicolas Huc COMSOL Employee
Posted: 7 years ago 12 mars 2018, 04:36 UTC−4
Dear Habimana, dear Sai Phani Kiran Hota,
Could you send a repeat model to the support and address it to me ? I'll be happy to check the issue and help to find a solution,
Best regards, Nicolas
Dear Habimana, dear Sai Phani Kiran Hota, Could you send a repeat model to the support and address it to me ? I'll be happy to check the issue and help to find a solution, Best regards, Nicolas
