Convention of pressures
Sebastian Sepulveda Cano
Hello good morning
I'm new using Comsol. I would like to know if it is possible to know the convention that software has by default for signs of pressures. I would like to know if NEGATIVE INPUT pressure values will be understood by the software as compression values and pressure values that the software receives as positive, which will be understood as traction values.
Thanks for your help.
0 Replies Last Post 15 févr. 2018, 13:26 UTC−5
Hello Sebastian Sepulveda Cano
