Comsol model in java
I'm working on a Comsol GUI application with the Java API. I used NetBeans and started with the beam model according to the Comsol Documentation (comsol-programmingReferencesManual.pdf pg.635) It works fine when i run it in NetBeans or eclipse but When i export the program to a runnable JAR file, it doesnt work. also it doesnt run in linux (debian) Anybody got the same issue?
The errors comes from this part of the source code:
ModelUtil.initStandalone(true);
This is part of the errors as follows:
Exception in thread "AWT-EventQueue-1" java.lang.UnsatisfiedLinkError: Can't load library: /home/m/Documents/lib/glnxa64/libcssystemutil.so at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1827) at java.lang.Runtime.load0(Runtime.java:809) at java.lang.System.load(System.java:1086) at com.comsol.model.util.ModelUtil$15.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at com.comsol.model.util.ModelUtil.initStandalone(Unknown Source) at com.comsol.model.util.ModelUtil.initStandalone(Unknown Source) any helps would be greatly appreciated. Thanks.
0 Replies Last Post 25 janv. 2018, 05:34 UTC−5
Hello Mohammad Es
