Using a the results of study 1 as an input of the second one.
Hi community,
I am working on a projet, I built my model made of four physics ( Laminar flow / Heat transfert in fluids / Heat transfert in solids / Transport in dilute sol) and then I got the results in a time dependent study where the last step of time is 1.0095 s, more detailed '' (0; 0.01; 1.0095)s ''.
What I would like to do ; I should start another study from 1.0095 s and use the results of both the heat transfert physics as an input of the second study (such as a continuity of the problem), where I am going to add another PDE equations to compute with. for more clarification, my new second physics to compute after the first study are : ( ''Heat transert in fluids and Heat transfert in solids'' starting as input from the results of the first study /PDE 1 / PDE 2/ PDE 3 ).
I would like to know what are the different possibilities and ways to make my problem, I am actually working in 3.5 and 5.2
Thank you, best regards!
0 Replies Last Post 18 janv. 2018, 06:41 UTC−5
Hello Anas Ben Ayad
