Fluid-porous Boundary condition
I'm working on modeling of porous media. I have two domains porous and fluid in the model. What’s boundary condition is proper in fluid-porous interface?
3 Replies Last Post 25 juil. 2011, 16:29 UTC−4
Hello Roohollah Sadeghi
Posted: 1 decade ago 19 juil. 2011, 10:44 UTC−4
Hi Rooholla,
Have you been able to solve your prob?
I am working on a similar proj involving 2 porous domains, and was wondering how to give an interface BC?
Thanks.
Shriram
Hi Rooholla, Have you been able to solve your prob? I am working on a similar proj involving 2 porous domains, and was wondering how to give an interface BC? Thanks. Shriram
Posted: 1 decade ago 19 juil. 2011, 11:52 UTC−4
Maybe you could upload an example file, containing your problem.
My first guess would be the conservation of mass: Flux_left = Flux_right. I myself have a porous electrode bordering a gas channel. I've described both with the same PDE and altered the transport parameter in each domain:
Gas channel: Total velocity = some value; Diffusion coefficient = 0 --> Convection only
Electrode: Total velocity = 0; Diffusion coefficient = some value ---> Diffusion only
By the nature of the PDE, conservation is fulfilled.
Philipp
Maybe you could upload an example file, containing your problem. My first guess would be the conservation of mass: Flux_left = Flux_right. I myself have a porous electrode bordering a gas channel. I've described both with the same PDE and altered the transport parameter in each domain: Gas channel: Total velocity = some value; Diffusion coefficient = 0 --> Convection only Electrode: Total velocity = 0; Diffusion coefficient = some value ---> Diffusion only By the nature of the PDE, conservation is fulfilled. Philipp
Posted: 1 decade ago 25 juil. 2011, 16:29 UTC−4
Yes, in comsol 4.0 there is a continuity boundary condition available under pairs, which takes care of the pressure and mass flux as you indicated to be continuous acorss the interface.
However, when I try to use this, I am unable to select the boundary.
Thanks.
Shriram
Yes, in comsol 4.0 there is a continuity boundary condition available under pairs, which takes care of the pressure and mass flux as you indicated to be continuous acorss the interface. However, when I try to use this, I am unable to select the boundary. Thanks. Shriram
