Problem with contact
Hi, I have a problem with this system: I have 3 elements, the upper one is a silicone membrane, the middle one is a piston and the lower one is a sample. I have a gap of 1mm between the membrane and the piston. I want to apply pressure on the surface of the membrane and observe how the sample deforms. I created two pairs of contact, one between the membrane and the piston and one between the piston and the sample. When I start the analysis, however, I get this error:Maximum number of Newton iterations reached
What's the problem? can someone help me? Thanks
0 Replies Last Post 1 déc. 2017, 04:15 UTC−5
Hello Fiorella Riccio
