Programming some commands
Hi, I'm using comsol 5.3. I'm working on a simulation in steady state results mode where I have a heat source which heats a part of the structure and with point evaluation menu, I measure the voltage at another point of my structure. Then I move the heat source to some other place and do the same thing. Is it possilble in comsol to write a program that does this sequence itself and save the voltage results in a file or something like that?
Thanks, Aria
0 Replies Last Post 8 nov. 2017, 16:54 UTC−5
Hello Aria Abbasi
