drawing a magnified deformation
Hello
i want to draw a magnified bending (caused by bending load) to have a visible bending (for example such as a cantilever).
i was wondering if it is possible by comsol?
thanks for your helps
behrooz
1 Reply Last Post 23 mars 2011, 02:08 UTC−4
Posted: 1 decade ago 23 mars 2011, 02:08 UTC−4
yous in V4 by default "deformations" are off, if you right click on the Plot Group Surface node you can add a deformation node. Then you can use the default scale or define your own
Hi yous in V4 by default "deformations" are off, if you right click on the Plot Group Surface node you can add a deformation node. Then you can use the default scale or define your own -- Good luck Ivar
