EWOD Simulation - Two phase laminar flow -The interface doesn`t move
Posted 16 sept. 2017, 14:52 UTC−4 Low-Frequency Electromagnetics, MEMS & Piezoelectric Devices, Computational Fluid Dynamics (CFD) Version 5.2a 0 Replies
Hi: I am currently working in a clasical EWOD simulation (I have attached the model). The model use the following modules:
CIR (Electrical Circuit) with a voltage source and a resistor to control the applied current, ES (Electrostaticas) : the voltage of the voltage source is applied through a "terminal" boundary (needle). A thin Low Permittivity gap simulates an hydrophobic layer. SPF (Laminar Flow and two phase laminar flow)
The ES and SPF modules are related by a Maxwell Stress Tensor calculation. In the "Volume force" boundary the components of the force in r and z coordinates (calculated from the MST) are introduced.
After I performed the simulation the results agree with the theory (preasure, and Force direction in the triple point), but the interface didn`t move at all. I think that with the current configuration I should see how the interface moves, but that is not the case.
¿How can I see the interface movement? ¿Am I making a mistake in the configuration?
Kind regards, Cristian
Hello Cristian Daniel López
