Center line velocity of curved 3D pipe visualized in 1D line graph
Posted 5 sept. 2017, 03:09 UTC−4 Fluid & Heat, Computational Fluid Dynamics (CFD), Results & Visualization Version 5.2a 1 Reply
Hello all,
I want to plot the center line velocity of a curved 3D pipe over the arc length which has several curvatures with different angles.
In the application library the example "Flow Through a Pipe Elbow" (www.comsol.de/model/flow-through-a-pipe-elbow-12221) exist.
Taking this example, how could I plot the center line velocity over the arc length? I want to compare the results with a 2D axis symmetric solution. In this case it is simple, just taking the axis of symmetry as data set and plot it.
Best regards
Andreas
Best regards
Andreas
1 Reply Last Post 5 sept. 2017, 13:34 UTC−4
