plasma module discharge application
Posted 20 août 2017, 23:03 UTC−4 Plasma Physics 1 Reply
got following issues when use this module.
1. can this module use in 1 atm pressure to calculate discharge? due to the 1 atm low-temperature plasma discharge phenomenon is exist.
2. adding Ballast resistor influence the discharge electron density or not? compare with ballast resistor is not there.
3. solver can not convergence when use AC(50Hz) load, is there any setting for AC?
4. do we should change some setting when the voltage load is high, like 460000V?
5. do you have some example for "The local field approximation" application, or the equation for mean electron energy vs electrical field for the setting area.
thanks a lot.
Hello 启友 许
