Circuit module issues
I tried to implement a circuit model in a multiphysics one. I need to use a mosfet from the circuit model. I tryed to make the simplest circuit. A circuit with two voltage generators connected with mosfet's drain and source but the simulation won't start. Comsol is keep saying that DAE is structurally inconsistent. Number of variable > Number of equations.
I appreciate your help, Stefano
1 Reply Last Post 2 juil. 2011, 21:55 UTC−4
Hello Stefano Larentis
Posted: 1 decade ago 2 juil. 2011, 21:55 UTC−4
Hello Stefano,
Facing the similar problem, but in transformer domain. So did you sort it out? I shall appreciate if could share that with me.
Hello Stefano, Facing the similar problem, but in transformer domain. So did you sort it out? I shall appreciate if could share that with me.
