Modelling laser ablation in COMSOL
I have a fairly simple question about COMSOL.
I have made a model in which a block is heated by a pulsing laser heat source.
I am using an iterative approach to solve it by solving for each pulse and then resolving with this solution as the intial conditions.
My question is would it be possilbe to actually 'remove' some of the material from the block, at each iteration, that has a temperature greater than a certain value?
e.g remove individual mesh elements if their temperature is greater than the vaporization temperature of the material.
I would really appreciate some help!
I have 2 weeks left to submit this project and would really like to get this working.
Thanks.
-Adam
13 Replies Last Post 21 oct. 2016, 15:28 UTC−4
Posted: 1 decade ago 1 mars 2011, 10:57 UTC−5
you cannot change the topology = geometry shape, but you could try to change the the material density and other properties if the temperature goes above a given value, hence you bleaches and simulate material removal. But I'm not sure how to, perhaps following some of the ideas of the non linear variable from the model Library "Loaded_knee", a nice "topology Optimisation (without really changing the entity topology)
Hi you cannot change the topology = geometry shape, but you could try to change the the material density and other properties if the temperature goes above a given value, hence you bleaches and simulate material removal. But I'm not sure how to, perhaps following some of the ideas of the non linear variable from the model Library "Loaded_knee", a nice "topology Optimisation (without really changing the entity topology) -- Good luck Ivar
Posted: 1 decade ago 2 mars 2011, 04:50 UTC−5
Hi Ivar,
Thanks for the help.
That is a clever idea, I shall give it a go.
Adam.
Hi Ivar, Thanks for the help. That is a clever idea, I shall give it a go. Regards, Adam.
Posted: 1 decade ago 2 mars 2011, 08:42 UTC−5
Please tell me if you are successful as I am trying to model something very similar. I am new to the thermodynamic analysis in Comsol so the question might be basic. I think Ivar answered this in his post by stating that the density can be changed but just to be sure:
Can phase changes occur during the simulation?
For example. If water is heated to its boiling point by a source, you said that the density can be changed in Comsol to correspond to water vapor. However, there is also a change in vapor pressure which will result in some acoustic effects. Can vapor pressure also be changed in a similar way?
Pretty much, I'm trying to simulate the violent boiling of water with a temperature input and a pressure distribution output.
Hi, Please tell me if you are successful as I am trying to model something very similar. I am new to the thermodynamic analysis in Comsol so the question might be basic. I think Ivar answered this in his post by stating that the density can be changed but just to be sure: Can phase changes occur during the simulation? For example. If water is heated to its boiling point by a source, you said that the density can be changed in Comsol to correspond to water vapor. However, there is also a change in vapor pressure which will result in some acoustic effects. Can vapor pressure also be changed in a similar way? Pretty much, I'm trying to simulate the violent boiling of water with a temperature input and a pressure distribution output. Thanks
Posted: 1 decade ago 10 mars 2011, 03:27 UTC−5
For boiling, see this model
www.comsol.com/showroom/gallery/3972/
For the removing/adding material see this model:
www.comsol.com/showroom/gallery/2112/
Niklas
For boiling, see this model http://www.comsol.com/showroom/gallery/3972/ For the removing/adding material see this model: http://www.comsol.com/showroom/gallery/2112/ -- Niklas
Posted: 1 decade ago 4 août 2011, 18:12 UTC−4
Dear Ivar:
I'm doing the modeling of laser machining. I already have heat transfer model, in which I can see the temperature profile.
I would like to remove the elements which is above the vaporization temp of the material to actually see the material removal by laser machining but I don't know how to do this.
I'm already using the level set method to distinguish between liquid and solid phase but no sucess for vapour phase.
If required I can send you the model file.
Please guide me.
Hitesh
Dear Ivar: I'm doing the modeling of laser machining. I already have heat transfer model, in which I can see the temperature profile. I would like to remove the elements which is above the vaporization temp of the material to actually see the material removal by laser machining but I don't know how to do this. I'm already using the level set method to distinguish between liquid and solid phase but no sucess for vapour phase. If required I can send you the model file. Please guide me. Hitesh
Posted: 1 decade ago 9 févr. 2012, 02:14 UTC−5
do you solved the problem? I find a lot of papers use the ALE to track the moving boundary.
but after lot of tries(using the prescribed mesh displacement), only to fail. Could you mind giving me some tips?
Thanks. Best wishes to you and your family.
Dear Ivar:
Please guide me.
Hitesh
Hi, do you solved the problem? I find a lot of papers use the ALE to track the moving boundary. but after lot of tries(using the prescribed mesh displacement), only to fail. Could you mind giving me some tips? Thanks. Best wishes to you and your family. [QUOTE] Dear Ivar: I'm doing the modeling of laser machining. I already have heat transfer model, in which I can see the temperature profile. I would like to remove the elements which is above the vaporization temp of the material to actually see the material removal by laser machining but I don't know how to do this. I'm already using the level set method to distinguish between liquid and solid phase but no sucess for vapour phase. If required I can send you the model file. Please guide me. Hitesh [/QUOTE]
Posted: 1 decade ago 25 oct. 2014, 18:38 UTC−4
I'm starting my modeling now in laser ablation of metals using COMSOL, if you have any material that help me please send it to me.
Fatema
I'm starting my modeling now in laser ablation of metals using COMSOL, if you have any material that help me please send it to me. Regards, Fatema
Posted: 1 decade ago 12 nov. 2014, 11:31 UTC−5
Hello Ivar,
I haved developed laser heating of a double layered material. Now I would like to remove some parts of top layered material. Can you please give me some idea in doing it.
Thanking you.
Meera kunden
Hello Ivar, I haved developed laser heating of a double layered material. Now I would like to remove some parts of top layered material. Can you please give me some idea in doing it. Thanking you. Meera kunden
Posted: 1 decade ago 17 nov. 2014, 08:49 UTC−5
I have developed laser heating of a double layered material. Now I would like to remove some parts of top layered material. Can you please give me some idea in doing it.
Thanking you.
Meera kunden
Hello, I have developed laser heating of a double layered material. Now I would like to remove some parts of top layered material. Can you please give me some idea in doing it. Thanking you. Meera kunden
Juan Miguel Auñón Garcia
Posted: 10 years ago 20 avr. 2015, 06:13 UTC−4
Thanking you.
Meera kunden
Dear Meera
I am facing the same simulations than you. Did you solve the problem of removing parts?
Best wishes
Juan
[QUOTE] Hello, I have developed laser heating of a double layered material. Now I would like to remove some parts of top layered material. Can you please give me some idea in doing it. Thanking you. Meera kunden [/QUOTE] Dear Meera I am facing the same simulations than you. Did you solve the problem of removing parts? Best wishes Juan
Posted: 8 years ago 13 juin 2016, 02:17 UTC−4
hi , i am facing the same model is anyone would help me please?
maher
hi , i am facing the same model is anyone would help me please? maher
Posted: 8 years ago 13 juin 2016, 09:19 UTC−4
Here is a blog on thermal ablation that you may find helpful:
www.comsol.com/blogs/modeling-thermal-ablation-for-material-removal/
Here is a blog on thermal ablation that you may find helpful: https://www.comsol.com/blogs/modeling-thermal-ablation-for-material-removal/ Best regards, Jeff
Posted: 8 years ago 21 oct. 2016, 15:28 UTC−4
Hello sir.
I am iterseted in the same as you already did. Can you tell me how to distingush between the solid and liquid? I am not interested in the evaporization. I am intersted in melting only.
Any documents or tutorials will be appreciated.
Thanks and best
A. I. Gad
Hello sir. I am iterseted in the same as you already did. Can you tell me how to distingush between the solid and liquid? I am not interested in the evaporization. I am intersted in melting only. Any documents or tutorials will be appreciated. Thanks and best ======= A. I. Gad
