Natural convection
Hi I'm beginner with comsol. I want to simulation the natural convection in the air. Heat transfer in fuid with laminar flow, It's works with short time (for 1 or 2 min) but it never give me results for more then 2 min. I have all the time this error message "Repeated error test failures. May have reached a singularity.".
Any idea why this is happening.
2 Replies Last Post 31 mars 2017, 13:04 UTC−4
Posted: 7 years ago 31 mars 2017, 00:58 UTC−4
Meryeme,
You can try refining your mesh or it could be because of incorrect boundary conditions.
Mahvash
Meryeme, You can try refining your mesh or it could be because of incorrect boundary conditions. Best, Mahvash
Posted: 7 years ago 31 mars 2017, 13:04 UTC−4
Start with a very small "load", which in this case, probably the temperature difference that drives the simulation. Make sure you have gravity enabled to be included as body-force term in the momentum equation. As the temperature difference gets larger, eventually the solution should get unstable. See discussion on Rayleigh number (en.wikipedia.org/wiki/Rayleigh_number).
Start with a very small "load", which in this case, probably the temperature difference that drives the simulation. Make sure you have gravity enabled to be included as body-force term in the momentum equation. As the temperature difference gets larger, eventually the solution should get unstable. See discussion on Rayleigh number (https://en.wikipedia.org/wiki/Rayleigh_number).
