4 févr. 2011, 08:00 UTC−5
I'm not sure what to propose, but a few comments:
I have noticed that COMSOL has managed to improve the way they consider geoemtrical "heritage" from earleir 3.5 version, and that this has been further improved in the latest (4.1 version compared to the early 4.0).
But, changing the number of elements in a model is a "topology change". And it's difficult for a programme (even for COMSOL) to guess right what you want.
Perhaps though, if you start with the maximum number of items, define all BC, and then decrease the number of eleemnts in your array, then the heritage will work better. But this is a pure "guess" from my side and I do not have access to COSMOL just now, to chekcit out, but worth a try both ways.
6 févr. 2011, 13:45 UTC−5
Hi Ivar,
I tried that, they don't keep boundary or subdomain conditions when you preset them and then change the number of array elements. Perhaps this is something you can add for the next version?
- Dave
Hi Ivar,
- Dave
6 févr. 2011, 17:23 UTC−5
well I cannot add anything to COMSOL, as I'm just a plain user as you, not linked to COMSOL inc, apart that I'm a fan of the programme, it so fun to do physics again with such a tool !
However, if you could think of a good way to decide how to allow COMSOL to heritate info when adding or changing the topology then I believe the developpers would be very interested to hear about it.
10 years ago
9 oct. 2014, 08:23 UTC−4
Hey guys, quick modeling question.
I'm using 4.0a, and I have a geometrical array (so, a repeated number of blocks) whose number of elements (size) is a parameter. If I increase the parameter, I get more elements, and so on. First off, I want to make the entire array, regardless of the parameter, part of the same union. It seems to me that it's impossible to add the whole array to a union instead of individual elements (of if there is a way I haven't found it).
Although this is an old post, I'm experiencing the same problem. Here is my solution in 4.4:
In the Geometry/Array properties, check the "create selection" under the "selections of resulting entities",
then make a new selection, name it "SelectionArray" (or something you like).
Next, create a union. Swith the "input objects" from Manual to "SelectionArray". This way all elements of the original array contribute to the union, regardless of the parameter settings.
Hopes that will help.
[QUOTE]
[/QUOTE]
8 years ago
25 nov. 2016, 09:50 UTC−5
Sebastian, many thanks! This advice is very helpful.
[/QUOTE]
[/QUOTE]
