defining a no-flux 2D surface on top of a 3D box
hi Everyone,
i'm qiute novice to comsol and have the following problem:
i need to to visualize diffusion in a 3D box made of GaAs that has a round mask on its top surface. now i know that i can just create a 3D thin mask of say Titanium, mesh it, have flux on the whole thing and solve. i was thinking though of not wasting mesh on a structure that its only purpose is to create a no-flux surface underneath it. so i was thinking to create a no-flux 2D round surface on top of the top surface of the GaAs box but couldnt figure out the way to do it. please help
10 Replies Last Post 1 mars 2017, 13:18 UTC−5
Posted: 8 years ago 24 févr. 2017, 12:05 UTC−5
Hello Saeed,
Is the box a parallelepiped?
If so, you can simply draw a disc in a workplane that coincides with the surface of the box.
If the box has a complex shape, see my last post in this thread: www.comsol.com/community/forums/general/thread/15263
Hello Saeed, Is the box a parallelepiped? If so, you can simply draw a disc in a workplane that coincides with the surface of the box. If the box has a complex shape, see my last post in this thread: https://www.comsol.com/community/forums/general/thread/15263 Best, Jeff
Posted: 8 years ago 24 févr. 2017, 12:19 UTC−5
hi,
the box is a simple box (parallelpiped) but how can i create a workplane?
hi, the box is a simple box (parallelpiped) but how can i create a workplane?
Posted: 8 years ago 24 févr. 2017, 12:22 UTC−5
You just right-click on the Geometry node and select Workplane. Same as other geometry operations, basically.
You just right-click on the Geometry node and select Workplane. Same as other geometry operations, basically. Jeff
Posted: 8 years ago 24 févr. 2017, 12:47 UTC−5
done so, and draw a circle, but i cannot see the circle when i am looking at my 3D geometry, is that the way it should be?
Posted: 8 years ago 24 févr. 2017, 12:51 UTC−5
ok ok.... i needed to tick somewhere, now i see the circle
ok, now how i define the flux and no-flux fields so that i dont mess things up?
ok ok.... i needed to tick somewhere, now i see the circle ok, now how i define the flux and no-flux fields so that i dont mess things up?
Posted: 8 years ago 24 févr. 2017, 12:53 UTC−5
sorry again ... did it on my own ... wow !!
Posted: 8 years ago 24 févr. 2017, 13:27 UTC−5
thnx for the help, still far from completing the model so i will keep annoying people here for a while :)
regards,
saeed
thnx for the help, still far from completing the model so i will keep annoying people here for a while :) regards, saeed
Posted: 8 years ago 24 févr. 2017, 16:31 UTC−5
Glad to hear you are making progress, Saeed.
To get acquainted with the graphical user interface, I recommend reviewing and working through the tutorials contained in the Introduction to COMSOL Multiphysics manual, version 5.2a, available here: cdn.comsol.com/documentation/5.2.1.262/IntroductionToCOMSOLMultiphysics.pdf and inside the software under File > Help > Documentation.
Glad to hear you are making progress, Saeed. To get acquainted with the graphical user interface, I recommend reviewing and working through the tutorials contained in the Introduction to COMSOL Multiphysics manual, version 5.2a, available here: https://cdn.comsol.com/documentation/5.2.1.262/IntroductionToCOMSOLMultiphysics.pdf and inside the software under File > Help > Documentation. Best, Jeff
Posted: 8 years ago 1 mars 2017, 13:10 UTC−5
hi again,
how can i attach a COMSOL file? the system does not allow me to
hi again, how can i attach a COMSOL file? the system does not allow me to
Posted: 8 years ago 1 mars 2017, 13:18 UTC−5
i saw that Jeff posted an mph file, how that can be done? the system gives me an error saying that the file extension is not legitimate
