Plot on certain domain or boundary only
I would like to ask how to plot quantity on the desired domain only. When I chose Surface plot or Volume plot, COMSOL always draws the quatitoes on every domain or boundary in the component. I can use multislice, but it is inconvenient because its just display on orthogonal plane.
Hope someone can hlep
4 Replies Last Post 14 janv. 2017, 06:44 UTC−5
Posted: 7 years ago 13 janv. 2017, 05:41 UTC−5
You can either add a Filter node to the plot, or a Selection node to the data set.
Henrik
Hi, You can either add a Filter node to the plot, or a Selection node to the data set. Regards, Henrik
Posted: 7 years ago 13 janv. 2017, 08:03 UTC−5
Thanks very much for reply.
I add Selection node to the Data set. My plot now look very neat and tidy. But I can not add many Selection node. I want to draw electric field out side metal and current inside metal. is it possible?
Thanks very much for reply. I add Selection node to the Data set. My plot now look very neat and tidy. But I can not add many Selection node. I want to draw electric field out side metal and current inside metal. is it possible?
Posted: 7 years ago 13 janv. 2017, 11:14 UTC−5
Solution 1: Copy the data set and use another selection on the copy. Use two plots with different data set selections in the same plot group.
Solution 2: Do not use the date set selection at all. Instead, use two plot nodes with different Filter subnodes. The syntax for using only say boundary 6 in a surface plot is 'dom==6' in the logical expression.
Henrik
Hi, Solution 1: Copy the data set and use another selection on the copy. Use two plots with different data set selections in the same plot group. Solution 2: Do not use the date set selection at all. Instead, use two plot nodes with different Filter subnodes. The syntax for using only say boundary 6 in a surface plot is 'dom==6' in the logical expression. Regards, Henrik
Posted: 7 years ago 14 janv. 2017, 06:44 UTC−5
The second solution is very convenient. Thank you very much for your guide.
