weird air flow
Posted 22 déc. 2016, 07:18 UTC−5 Fluid & Heat, Geometry, Modeling Tools & Definitions, Parameters, Variables, & Functions, Studies & Solvers Version 5.2 0 Replies
I want to simulate an air flow. The real model is as follows:
The air is sucked in by a fan and flows through 2 lattices which lie one on top of each other and have a distance of 4 mm. The sides are covered with walls.
That brings me to the 3D Model with the size:
4 x 111 x 67 mm
I defined the top and the ground to be lattices, the front as outlet, the sides as walls (no slip).
When I now run simulation I get a weird air speed distribution, I can't understand.
It starts to get faster and faster and reaches 4m/s at the outlet, what is pretty logic.
But short before the outlet it is close to zero, what I can not at all understand.
Am I doing something wrong?
Please feel free to correct my work or my model as I do not have any experience with comsol.
thanks in advance,
ben
Hello Ben M
