Failed to find consistent initial values
Posted 9 déc. 2016, 06:44 UTC−5 Fluid & Heat, Computational Fluid Dynamics (CFD), Microfluidics Version 5.2a 4 Replies
Dear all:
I am trying to couple two phase flow and structure mechanics together. In case of generating the huge gap between the initial condition and boundary load ( also inlet), I have already include a step function to eliminate this potential problem. However, it still has this consistent problem. I have also tried step by step, where I start with only two phase flow, phase field and moving mesh which works fine. Dependent on that, I add solid mechanics, where I fixed the interface between the flow and solid structure, and it also works fine. However, when I introduced the moving boundary into the interface, where flow and external load will deform the interface layer, then model goes wrong. Can any one help me to fix that? Thanks a lot. By the way, I also tried with add a point pressure constraint in the model, and it dodes not help.(Hint from previous discussion)
Here is the error:
Undefined value found.
NaN or Inf found when solving linear system using PARDISO.
- Feature: Time-Dependent Solver 1 (sol1/t1)
Here is the error:
4 Replies Last Post 6 mars 2017, 12:05 UTC−5
