spiceimport
Hi All,
Did anyone try looking inside the spiceimport.m file ?
I tried to use this command with no luck. I get the following message:
Exception:
com.femlab.util.FlException: Could not find any matching floating point conditions
Then, I tried to open the file(spiceimport.m) and see what is happening. Thought that is a small
file, I couldn't understand whats happening. Mainly the following line:
cir = spice.importNetlistFromFile(filename,rep)
I thought this imports the spice netlist and uses it to extract ode parameters. But
I didn't find this variable(cir) used anywhere after this line.
Any comments?
1 Reply Last Post 19 janv. 2011, 20:27 UTC−5
Posted: 1 decade ago 19 janv. 2011, 20:27 UTC−5
I forgot to mention this.
Can anyone using COMSOL 4.0 or 4.1 check if the variable 'cir' in the file spiceimport.m
is used after it has been defined ?
I forgot to mention this. Can anyone using COMSOL 4.0 or 4.1 check if the variable 'cir' in the file spiceimport.m is used after it has been defined ? Thanks
