Adhesive in shell physics
I am trying to build a sandwich panel in Comsol 5.1 by attaching the facesheets to the extruded honeycomb cells by a certain glue. I read different threads, but was unable to find the solution. The problem is in the Shell Physics the only pairing option is continuity. I will be so thankful if someone let me know how I can consider the effects of a layer of glue between the a set of extruded honeycomb cells and two panels on the sides.
0 Replies Last Post 22 nov. 2016, 18:00 UTC−5
Hello Ehsan Nabiyouni
