Why is thermal expansion not happening along +Y and +Z direction?
Posted 8 nov. 2016, 18:44 UTC−5 1 Reply
I am trying to do a test simulation where a 3D bar is heated all around and expanded according to the thermal expansion coefficient. In the attached file, I have applied roller BC on the -X, -Y and -Z faces of the bar. I expected that the expansion would happen in the +X, +Y and +Z directions. But this only happens in the +X direction. But if I prescribe a roller BC on the +X face also, I see that expansion happens in both +Y and +Z faces. I set the Poisson's ratio as 0.0. Is my expectation wrong?
Thank you,
Stephen Thomas.
Thank you,
Stephen Thomas.
1 Reply Last Post 8 nov. 2016, 18:49 UTC−5
