Comsol not starting on Win10 with normal user
Dear all,
when I try to start Comsol 5..2a on our upgraded Windows 10 mashines, the attached error log occurs. *But* when I use an admin account, I can use comsol without problems.
FlLocale - SystemProperties do not contain any locale setting.
Constructing a FlLocale:en_US
InitNativeRenderDevice with screenDpi:96
The pipe is being closed.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.Pipes.NamedPipeServerStream.WaitForConnection()
at Comsol.JavaCommunication.JavaBridgeCommandManager.WaitUntilConnected()
at Comsol.Communication.ChannelBasedCommandManager.InitializeConnection(ClientType clientType)
at ComsolDesktop.MainWindow.StartJava(Boolean devPlugins, List`1 jvmArgs, NDisconnectInfo disconnectInfo, IBridgeCommandManager oldMgr)
at ComsolDesktop.App.OnStartup(StartupEventArgs e)
at System.Windows.Application.<.ctor>b__1_0(Object unused)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
3 Replies Last Post 31 janv. 2017, 08:47 UTC−5
Sven Friedel COMSOL Employee
Posted: 8 years ago 4 nov. 2016, 07:50 UTC−4
Dear Markus
I see there being two items to try to resolve this.
The first is to try opening COMOSL using an alternative method.
www.comsol.com/support/knowledgebase/1068/​
The additional resolution is to have COMSOL rebuild the profile, these can be found at: C:\Users\Markus\.comsol
You will want to rename the v52a and v52 folders (or delete them if the settings therein are not so importnat).
Sven
Dear Markus I see there being two items to try to resolve this. The first is to try opening COMOSL using an alternative method. www.comsol.com/support/knowledgebase/1068/​ The additional resolution is to have COMSOL rebuild the profile, these can be found at: C:\Users\Markus\.comsol You will want to rename the v52a and v52 folders (or delete them if the settings therein are not so importnat). Best regards, Sven
Posted: 8 years ago 30 janv. 2017, 07:51 UTC−5
Thanks Mr. Sven, I also benefited from your comment.
I deleted the files of the two COMSOL versions, so COMSOL is working properly now.
Thanks Mr. Sven, I also benefited from your comment. I deleted the files of the two COMSOL versions, so COMSOL is working properly now.
Posted: 8 years ago 31 janv. 2017, 08:47 UTC−5
My pleasure to hear that. Enjoy modeling!
Sven
My pleasure to hear that. Enjoy modeling! Sven
