Calculation of ∇.(k∇T)
I want to calculate the value of ∇.(k∇T) when T=800 and use it in another equation. Is it possible using COMSOL? Can anyone help me?
Krish
2 Replies Last Post 1 sept. 2016, 13:41 UTC−4
Posted: 8 years ago 1 sept. 2016, 12:11 UTC−4
Hello Krish,
If T=800, then ∇.(k∇T)=0 .
Hello Krish, If T=800, then ∇.(k∇T)=0 . Best, Jeff
Posted: 8 years ago 1 sept. 2016, 13:41 UTC−4
Hello Jeff,
Thank you for responding. I want to calculate net heat density (Heat in -Heat out) at each element in the domain when the temperature of that element reaches 800K. Is it still zero? And I want to use that value in other equation.
I appreciate your help.
Krish
Hello Jeff, Thank you for responding. I want to calculate net heat density (Heat in -Heat out) at each element in the domain when the temperature of that element reaches 800K. Is it still zero? And I want to use that value in other equation. I appreciate your help. Krish
