Extrusion operator query
I have a 1-D model. It consists of 2 physics; 1 is a coefficient form PDE evaluated across the 1-D domain and the other is lower dimension coefficient form PDE evaluated at one of the boundaries of my 1-D problem.
I want to use the value of the dependent variable evaluated by the lower dimension coefficient form PDE across the whole domain in the 1st PDE.
Is this possible to do in comsol using extrusion operator??
Thanks in advance
Vishnu
1 Reply Last Post 14 juil. 2016, 02:53 UTC−4
Posted: 8 years ago 14 juil. 2016, 02:53 UTC−4
Yes, this is what Extrusion couplings are for. You can "extrude" a variable from a dimension into another dimension using a coordinate transformation.
If I read your post correctly you just wish to use the value of a variable that is defined in a point in the rest of the model. In that event it may be easier simply to add an integration coupling (found under Definitions->Component Couplings) for a the single point that makes up your boundary.
Lars Gregersen
Comsol Denmark
Hi Yes, this is what Extrusion couplings are for. You can "extrude" a variable from a dimension into another dimension using a coordinate transformation. If I read your post correctly you just wish to use the value of a variable that is defined in a point in the rest of the model. In that event it may be easier simply to add an integration coupling (found under Definitions->Component Couplings) for a the single point that makes up your boundary. -- Lars Gregersen Comsol Denmark
