Is the LiveLink command mphint2 appropriate using the cut line dataset?
Panagiotis Dimakopoulos
In Livelink application for MATLAB there is the command mphint2
using it to evaluate the results. In the evaluation of Derived Values I want to use the selection Cut Line 1 {cln1} instead of the Solution 1 {dset1} selection.
The command is
data = mphint2(model,<expr>,edim,'dataset',<dsettag>);
Can I use the selection Cut Line 1 {cln1} instead of the
Solution 1 {dset1}.
Or I must use an other command like mphglobal?
Thank you in advance
2 Replies Last Post 12 juil. 2016, 19:44 UTC−4
Posted: 8 years ago 12 juil. 2016, 02:55 UTC−4
Yes, you can use mphint2 with other datasets including Cut Lines.
Lars Gregersen
Comsol Denmark
Hi Yes, you can use mphint2 with other datasets including Cut Lines. -- Lars Gregersen Comsol Denmark
Posted: 8 years ago 12 juil. 2016, 19:44 UTC−4
Yes it works!
The complete command is:
data = mphint2(model,<your_expr>,'line','dataset','cln1');
Yes it works! The complete command is: data = mphint2(model,,'line','dataset','cln1');
