CTE Syntax error
Hello everyone, I'm currently trying to define a function under the basic properties of the built-in silicon so that I can include a temperature-dependent coefficient of thermal expansion in my model. My expression for this CTE, which I gleaned from an old NIST paper is as follows:
-(0.687*10^(-6))+(5*10^(-6))*[(685/T)^2]*e^(685/T)/[exp^(685/T)-1]^2+(0.22*10^(-6))*[(T/395)-1]^2/[1+0.316*(T/395)]
I understand it's a little hairy with all of the coefficients but if anyone familiar with entering functions in to COMSOL might be able to point out something wrong with it, it would be greatly appreciated. I'm currently getting a syntax error. It is eqn (1) of this paper: www.nist.gov/data/PDFfiles/jpcrd220.pdf
Thanks as always.
3 Replies Last Post 15 juin 2016, 13:31 UTC−4
Posted: 9 years ago 15 juin 2016, 13:15 UTC−4
The problem is likely the square brackets: try replacing them with regular parentheses.
Square brackets are used in COMSOL to indicate units. That's just my .02[USD].
The problem is likely the square brackets: try replacing them with regular parentheses. Square brackets are used in COMSOL to indicate units. That's just my .02[USD]. Best, Jeff
Posted: 9 years ago 15 juin 2016, 13:16 UTC−4
...and exponential of x is exp(x).
...and exponential of x is exp(x). Jeff
Posted: 9 years ago 15 juin 2016, 13:31 UTC−4
Awesome, thanks Jeff!
