Joule Heating in changed gas presser (in vacuum)
Василий Дружинин
Hello!
I have such problem.
Electrical conductor connected to a DC power source. Placed in the rarefied gas.
It is necessary to see change temperature conductor, depending on the gas pressure.
I have used the module Joule Heating. In module Heat Transfer in Solids I have added the part Heat transfer in Fluids, and changed the pressure in area (cylinder of gas). But I couldn't get this depending (depend temperature conductor from pressure gas).
Who decided whether a similar problem?
1 Reply Last Post 27 oct. 2016, 03:29 UTC−4
Hello Василий Дружинин
Posted: 8 years ago 27 oct. 2016, 03:29 UTC−4
Hello ;
Have you checked your material properties ?
i hope i understood correctly , to notice the change of temperature in the electrode, your material should be a function of pressure , u also might need a flow coupling.
Best of Luck
Hello ; Have you checked your material properties ? i hope i understood correctly , to notice the change of temperature in the electrode, your material should be a function of pressure , u also might need a flow coupling. Best of Luck
